Hi folks, I have recently purchased a 290 hitachi with about 7700 hours on it. There is an issue and my mechanic has been on it for 2 days, hoping someone here my have had the same problem. The right hand track is slower than the left. To put it in perspective, if you went forward around 100 feet.... you would be going where you came from. It does it in both directions. The obvious have been checked, pump pressures, drives tested well, center joint is fine. Mechanic said it was going straight and fine for about 10 trips up and down the yard....I got in it and still pulling to the right. One thing that stands out is that the right track pedal/hand lever was replaced recently. No idea why it was replaced tho. TIA
