That fit nicely against the forward most plate of the telescoping assembly. It did leave me with a nominal ¾ gap between the end of the pin and the cutting edge I just welded in.
Gonna take a step back here.
Normally, I would have made an a frame out of box tubing from the center of the cutting edge that I welded in to the corners of front part of the frame. Or I would have used some heavy sidewalled box tubing to do the same job as the broken pin. I didn't have the patience today to figure out the angles for the a frame. I didn't have a lot of options in heavy walled box tube and even if I did, it would have to be cut at an angle so I could fit it between parallel plates. Then I would have to try to fill in a gap on the underside. I bet more than a few of those reading this wouldn't consider that a problem. Wish I had your skills.
Anyway... that broken pin was just begging for a new opportunity to be of service. If it wasn't, It wouldn't have broken perfectly square.
As for the ¾ gap? Well it just happens that last week I had to relocate pins on an npk h7x last week. Guess what thickness the side plates were? Yep.
