gatorchevy88
I have a 259D (FTL14492) (ESN 8HN5725), with a rather confusing issue.
cold: with key no start. key on engine off if you press in the relay it will start no issue
cold - warm: will start same with relay, and will kind of start eventually after a few cranks with key and flutter pedal
hot: starts immediately with key and relay
have replaced fuel rail, transfer pump, filters, engine wiring harness, machine ECM, tried to replaced engine pcm (site to reprogram c3.3 currently down).
conducted a cylinder cut off test and the delivered fuel injection was 16.7 - 18.3 mm3 across the 4 injectors. I believe spec is 25mm3. not 100% positive. however fuel rail PSI was in spec at low and high idle
slightly weird issue because every path you get on to see why it wont start with key all theory gets shut down because it will start with power relay when pressed
thank you in advance for help
