257B new to me -- does it have high speed?
707pc50
california
I just purchased a new to me 257B 600hrs seems really nice. I am wondering about high speed travel. It has the graphic next to the left hand joystick with a symbol denoting the trigger does "rabbit/turtle" and there is a light upper right side of the cage that indicates "rabbit/turtle", when i click the trigger nothing changes speed wise, and the light doesn't go on. Does my machine have high speed? I assumed it would go into a teeth rattling travel speed, am I wrong? Please advise-
Mark250
victoria,Australia
heavy equipment technician
hi As you have not provided a serial number I am assuming that it is a B3 since the earlier models did not have two speed and would have a serial number prefix of B7H. here is a description of the earlier version.
To tell for sure lift the cab and support. on the left hand side rail will be a manifold with either one or two solenoids if there are two solenoids it has two speed.
Mark
707pc50
california
Ok it's at a job, a helper texted that number over, I'll go and look tomorrow and correct this, thanks
707pc50
california
Im a rookie here, can someone else help me a little more, didn't see anything where bucket lift cylinder attaches to frame
Try the illustration below.
Depending on the year/model the PIN Plate (1) is located on the left side of the machine. Or on the back left part of the frame or under the lift arm on the left side.
The serial number plate (2) for the engine is located on the left side of the engine block. (If you can supply an engine S/N we can track down the machine S/N from that, or at least we should be able to)
