Question what is or where do you buy a 7812?
Electronics geeks 1.5A 12V output voltage regulator -- the TO-3 case survive up to 2.3 or 3 A with a lot of heatsink. Here's a link (but Radio Shack might still have them, if you still have a shop open near you):
http://www.digikey.com/product-detail/en/L7812CV/497-1452-5-ND/585973 Link also has datasheet with "application circuit" diagram that includes a couple extra capacitors to enhance performance of the part. You are limited to about 18 Watts of power, though, unless you heatsink the heck out of it. For a permanent install of a small stereo, I'd almost consider a 7815 (15V 1.5A) since a lead acid battery will charge upwards of 14V, so a cheapo stereo should survive and you'd get about 22 Watts through it, and I'd screw the TO-220 case to something metal with bulk to pull heat off.
For a little more money and a few extra components, you could hook up a pair of LM317s and set them to 13.8V, but that starts to resemble work -- the LM317 is a variable voltage regulator, works great in the right situation.
http://www.digikey.com/product-detail/en/LM317T/LM317TFS-ND/458678 Link also goes to a datasheet with more info and suggested circuits -- about 15 years ago, the senior technician and I came up with (and tested, that was the scary part) a circuit design based on two of these that lets us set constant voltage and constant current to charge lots of lithium ion laptop batteries, still using them today.
Good luck!
Mike the EE
