Phishphan1995
So the machine only has 51hrs on it. Serial #JX911421
Its only used for snow removal and unloading pallets and moving material around at the shop.
So we had a snow event last week machine ran fine for 3 hrs then operator called and said he lost power. So I went over the site he was on. Looked things over no active codes but the E875-2 code was stored as a event. We shut machine down let it sit for a bit and finished the job.
Then today we had another snow event. The machine started and ran fine 4hrs in operator calls me says he is stuck in the middle of the road machine wont start. So he let it sit till I got there. I got in and the volts were at 11.7 I got it to start and let it idle the volts went up to 14.6 and stayed steady I started to move the machine to get it out of the road. And the volts stayed between 14.3 and 14.6 but the machine was basically in turtle alimp mode I got it down to a place where I could park it.**** it off and turned key back on volts were back at 11.7. Not sure what's going on.
There is no active codes once again. But these codes are stored. I'm not sure what to do. We are expecting more snow in 1.5 days need to get this thing running.
I'm furious I have a ma hone with 51hrs on it and having problems. I'm considering calling altorfer and raising hell the machine went out of warranty October 21st 2024. I feel like they should stand behind there product and get there ass out here and fix it. Anyone have any experience with getting them to fix it when it had that low of hrs and just out of warranty?
Any help advice would be greatly appricated
Thanks for your time!
