2015 Komatsu D85PX-18 CAN issue
B0508
Fountain inn
Started with DEF/emissions derate codes. Machine was running but derated.
Found broken wire between ECM J1 and SSR relay circuit. Repaired wire and regained power on pink wire feeding DEF-related modules.
Now machine is a no-start.
Current findings:
  • CAN resistance checks good at ECM J1/J2 (~60 ohms)
  • CAN voltages appear correct
  • Checked NOx sensor circuits
  • Unplugged both NOx sensors
  • Tested sensor on large SCR can and DEF tank module
  • Reduced active codes significantly following troubleshooting
  • Harness has been double checked
  • Following Komatsu service manual troubleshooting tree
Machine ran before beginning electrical repairs, now crank/no-start.
I have NOT located the SCR/DEF controller yet. Does anyone know exact location on D85PX-18 serial 22042?
At this point I feel like I’m missing something simple.
