ChiefStone
Hello all,
Ran into an odd issue with our 2014 TB240 over the weekend...
Operating fine and out of the blue got a warning flashing on the control panel, looked it up, and it's error code 1704, "Main power supply voltage error; Voltage low".
Machine operates fine, other than the warning buzzer going off every 5 seconds...
System voltage on the control panel reads anywhere from 3.8-5.4 during key on, doesn't matter if engine is running or not.
Meanwhile, confirmed battery voltage is 12.5 across terminals with machine off, and it is charging, with a voltage reading of 14.4-14.6 while the engine is running.
No blown fuses or any chafing that I can find on the main harness... I'm stumped. Anyone ran into this before, is there a common issue that this could be related to?
Does anyone know where the control panel picks up the voltage signal from in the harness/ecm?
Thanks all!
Thanks all!
