Magnum402
Hello.
I purchased an inoperable 2014 JCB 320T with the Exomax T4i motor SN: GEO320TVCD2196986. I got the machine running and determined that the engine needed to be replaced as it was run without oil. A used 2017 Exomax engine with 59 hours was found as a replacement. The engine details and ecu matched the 2014. The replacement engine cranks but will not start. Using the Servicemaster4 software the ECUs have been reflashed and tomorrow I will reset to factory defaults as this was not done. The compression is good, the rail pressure is over 300 Bar, the engine cranks at over 200 rpm, the cam sensor was swapped for a known good one, there are no codes, and all sensor data looks normal. The part numbers for the wiring harness from a 2014 and a 2017 are identical.
When cranking the right cluster displays "delay". I assume that this is for the grid heater, but I do not know if this is normal. If this is related to my no start problem or if you have any suggestions it would be appreciated.
Thanks.
Thanks.
