2014 Case SR250 Skid Steer, Intense Blow-by is Emptying my Crankcase Oil out the Dips Stick tube!
hd66
Vancouver Canada
I've owned it 2 years and less than 20 hours put on it in that time! 1770 hrs approx on meter. Used it about 2 months ago for 3 hours and no problem with engine. A week ago it was used for about 1hr and then I Shut it off after using and opened engine compartment to shut off the power switch. There was Oil all over engine,rad etc..o_O. No oil not showing on the dip stick! I added oil and started it. Removed oil filler cap and intense blow-by coming out along with lots of oil! Also Puking oil out the dipstick tube. Understand this was not a gradual degradation of the engine and there's been nothing previous to this to indicate a problem. It sounds fine when running. No strange noises. Starts normal. Possible hole in Piston or broken piston?
aongheas.macask
Scotland
ex service manager
Anything is possible but check the easy things first, make sure the crankcase breather is not blocked, if ok do a compression test and that will indicate bad piston, stuck or broken piston rings etc.
hd66
Vancouver Canada
All good recommendations coming in! If anything Rare is going to happen to anyone, it's me.....! I wish it to be something simple like a plugged crankcase breather and or filter. If it's something bigger, I hope it's the Turbo Seal instead of something catastrophic in the engine!
63 caveman
western Pa.
if you had a dead hole that thing would be shaking and down on power. I'm with Coaldust on this one. BTW don't forget to make sure the oil drain tube is clear on the turbo.
hd66
Vancouver Canada
Thank you. Had me baffled that engine performance is normal. Nothing was alerting me to a problem. I imagine the engine could have seized up if run much longer. Will be checking everything closely.
hd66
Vancouver Canada
I think I need a service manual. This is called operators manual. 221 pages. Useful info but don't see the Crankcase Ventilation in it. Still looking. Not very user friendly in the PDF format, imho.
UncleHenry
Mt Carroll, Illinois
hd66: I have got the same problem with my Case SR250. Did you ever resolve your issue?
It is not my turbo or oil return line, or air filters. All new.
Am about to begin the replacement of the "blowby recirculation filter", whatever that is, (crankcase ventilation?) as recommended in the operators manual at 2000 hrs. I am well below that at 1400 hrs., but after obtaining a new "blowby filter" at the Case dealer, I can see how easy it could probably become blocked and plugged well before 2000 hrs.
I bought a 2 volume Case SR250 service manual, and I cannot find anything in it about "blowby recirculation filter" or its function.
Thanks ahead for any feedback on this.
Simon C
Heavy Equipment Mechanic
FYI you can easily disconnect the turbo. Plug the oil feed line that feeds the turbo. Plug the drain line that goes back to pan. Start the engine at idle with no manifold on and you will see which cylinder is causing grief , if that is the problem. I did it recently to a Komatsu D155 dozer engine to find out which cylinder was not firing properly. Not even that noisy with plugs and muffs.
Hopefully your crankcase vent is plugged, or tubo seal is gone and not big hole down side of piston.
Hope it helps.
Simon C
hd66
Vancouver Canada
I've done nothing so far. Where's the blow-by re-circulation filter? I might toss it out and not use one! Have not found a diagram of it yet.
Simon C
Usually there is some kind of hose that comes off of the Valve Cover that either goes to vent out bottom of machine, or goes back into the air intake to reburn. Not sure on your unit, but operators manual may have something on cleaning out or servicing of crankcase ventilation. If you find a hose coming off the valve cover and send it out towards the air , you can see how much real blow-bye there is with the engine revved up and hydraulics running over relief.
Engine needs to be warmed a bit and revved up and under load.
Simon c
UncleHenry
hd66: I have found NO info on this filter on internet. Only mention of it is in Operators Manual under 2000 hr maintenance. (Section 7-45?) No mention of what it is or what it does...... it is located on the lower right on back of engine, on what I believe is timing gear cover. There is a "picture" of the cover to be removed in op manual. You need to remove turbo air cooler & hoses above radiator, the radiator & hoses, fan shield, and fan blades to get to it. (3) 10 mm nuts holding on cover. I did not remove attached hoses on cover, it pushes out of way pretty well. I took mine out this morning, (wasn't too bad a job getting to it other than all the oil all over everything from it spitting it out dipstick!), Filter is held in place by a decent sized snap ring on a spindle. Had to invest in a heavier duty snap pliers. Hope to get the snap ring reinstalled tomorrow, and start putting the radiators back on. Going to wash and flush out everything with solvent to try to get the oil out of air system.
Filter I took out is obviously part of the oil system, as it looks like an old dirty oil filter after a period of time. It does not look "plugged", Element seems to be a polyester fiber. Is not very big, coffee cup diameter, maybe 1.5 in. thick.
If I get it replaced and back together, going to run it up to temp incrementally, checking oil and coolant regularly, before working it hard.
If this does not work, it has been suggested that I try a motor flush cleaning treatment by Amsoil, Cenpeco, or the like. Might consider doing it anyway, as obviously something is gumming up the system, and needs to get out. Why they put this "blowby filter" in such an inaccessible area to check and service is a mystery......
Will let you know if this works. Good luck on yours. Thanks for starting this thread.
hd66
Vancouver Canada
Thanks for all the details and the best wishes dealing with my Skid Steer! Will save me time knowing the details. Nice to have someone else dealing with the same issue on the same model Skid Steer. I definitely have to get at that filter. Will look for the cover pic in my manual. Not looking forward to changing the filter. Hope you get a good result.
UncleHenry
I looked again today, and it's section 7-63. Got my snap ring back on and reinstalled he cover, but that is as far as I got today. The filter seems to have two oval openings opposite each other on the inside, that I assume need to be positioned directly over what look to be corresponding holes in the spindle that the filter slides onto. Had to push and tap the new filter on pretty firmly to get it past the snap ring groove.
There are little collar inserts on the 3 10mm bolt holes on filter cover. One of mine slipped out on reinstall, but I was lucky to fish it out from below in all the oil muck. Watch them.
Never did this before, but am going to try to attach image. I took this with the new filter installed and snap ring in place. Cover is at right hanging loose. Hope this helps. Hope this solves our problem! Blowby recirc filter house.jpg
