Monkeywithawrench
So my service truck 2012 Freightliner M2 blower doesn't work on HIGH speed. Every other speed works (1-4), just not high. I replaced the blower motor last year. Tried a new control head........no joy. Its driving me nuts why this isn't working on high. So the blower motor has the 3 wires...Big black, Big Blue, and little blue. All speeds the big blue and black (Power and Ground) provide 12V so its not the usual suspects of a power issue at a connector or fuse block. The little blue wire (which is the speed controller for the stupid board inside the fan is doing what it should. With the plug connected to the fan, fan running on the different speeds, the reference voltage from the small blue wire coming out of the plug at the fan steps down in voltage with higher speeds.
SPEED BIG BLUE WIRE VOLTAGE (FAN POWER) LITTLE BLUE WIRE VOLTAGE (SPEED CONTROL)
0 (0FF) 12V 11.62V
Between 0 and 1 12V 7.51V
1 12V 6.49V
Between 1 and 2 12V 5.49V
2 12V 4.46V
Between 2 and 3 12V 3.35V
3 12V 2.34V
Between 3 and 4 12V 1.34V
4 12V 0.63V
So it seems every speed higher is a drop of about 1V on the signal wire at the blower motor. I've tried grounding out the signal wire to the ground wire at the plug on the fan..........one would assume that the fan would kick into HIGH with no reference voltage for the speed signal, since with the fan switch in the OFF position it gets 12V on the signal wire.
I'm assuming the blower motor control board 'MIGHT' be bad since its not kicking into full bore HURRICANE mode. I'm just not willing to throw another $250 at a blower motor just to try it.
Anyone run into this problem?? Anyone have this type of blower on their truck?? I'm wondering/ would like to know what they get for voltage at the signal wire on HIGH SPEED (4) , plug inserted into working blower motor.
Thank you!!
0 (0FF) 12V 11.62V
1 12V 6.49V
2 12V 4.46V
3 12V 2.34V
4 12V 0.63V
Thank you!!
