2009 Kenworth T800 Window Wipers Only Run On High Need Advanced Help
JamesRSt
The South
Hello,
I've got a 2009 T800 that's giving me some issues. The wipers will only run on high setting and I'm getting no power to the Window Washer either. I have checked every single fuse, put a new blower motor on, and tried two new relays but I still have the same issue with no change.
This has me thinking it might be an issue with the window control module but before I sink any more time into this I figured I'd see if anybody else can help out.
I will edit this post with some more information shortly but just wanted to get it up asap to get some eyes on it.
Any help is greatly appreciated!
-James
Not positive but starting in those years some cab accessory's are computer/module controlled. I know lights are. Mounted behind center
dash panel, a box about 4" x 4". Call KW with vin #.
Greatwestcam
Northern Alberta
Driver/Mechanic
We find most issue is with the turn stalk control. If you have access to a good one just plug it in and try it. Just pull the center gauge panel with tac and speedo out, you can see the connector lower right area.
PeterG
United States
Contractor
I Had similar issues with 2007 T800. Windshield wipers not working on intermittent. Replaced multifunction module. Windshield washer not working. Replaced washer pump and seal.
