alaskaforby4
I have had a head scratcher for the last couple years and. After sitting for a winter (16-17) we fired up this 2006 John Deere 160 CLC Excavator and it ran great, we were working it on a job and shut it off. After we restarted it it idles fine but as soon as you idle it up it runs terrible, missing and the whole motor shutters, sometimes puffs of black smoke. Obvious fuel issue. Well, that where it gets interesting. If you shut it back off and restart it, everything runs fine. Sometimes you have to restart it once, sometimes 3,4,5 times but it will always eventually run normal. 65% of the time it just starts and runs fine. Also never has a problem at 1st start of the day. Ive been hoping it would develop move, but its not getting any worse. So, Ive replaced the filters multiple times, drained the tank, blown through the lines into tank, inspected tank, replaced lines to tank, bypassed fuel cooler, replaced lift pump, replaced gaskets in pre-pressure lines, replaced crank sensor.
It dosent throw any check engine lights. Dont know about stored codes, dealer is very far away. I always run with the A/A & A/I off but am currently suspecting it may be one of these sensors sending conflicting information to computer. Looking for ideas now. Thanks!
