walkerv
Changed output sensor as that was the active fault. It wasnt the problem quickly investigated wiring in the dark didnt see anything wrong or bad with it yet. Truck has a cummins and an alisson. stamp steel oil pan with tiny screw on filter didnt look at the tag, has a standard column shift like a pickup truck . Only thing i found quickly smoking over it was the batteries got changed and the terminals weren't cleaned they are nasty. Going to remedy that problem tommorrow as i think its a voltage problem due to it . If that doesnt fix it i am looking for some guidance in the rite direction as it seems this vintage and model seem to have this problem frequently with this transmission combo , all fuses appear to be in good shape also but will do a more thorough check in the daylight, truck has been sitting unused for 10 months .
