onehandman1
Hello All,
It seems my grid heater doesn't work. Hard starting when cold. The only time i see the glow plug light is with initial key on. What my testing has done for me... in a heated garage 62F the temp sensor on top of engine 2500OHMs(i believe this is good). Wiring ohmed out from sensor to the "module". The relay works. Clicks when supplying 12V to it and it connects the high voltage side. The "module" has 12 V and ground going to it back probed with a DVOM. It also has a "good" ground. Measured ground by checking continuity (I know this isn't the best way and it should be load tested.) I never get 12V going to the heater grid relay. I believe the iveco heater grid "module" isn't working properly, but wanted to make sure I didn't miss anything silly. I can tell the previous owner of the machine was also trying to diagnose as many of the connector locking clips have been broke related to the heater grid system.
Thanks in Advance.
Paul
Thanks in Advance.
Paul
