Hi Guys/Gals,
Background story:
Bought a 2003 Caterpillar 160H Grader with 11,000hrs it is a fairly clean unit and has a major work order for a replacement longblock and few other misc items. Before we put it into service we had our in house mechanics check it over and found that there was coolant mixing with the transmission fluid. We diagnosed the issue as a bad cooler and replaced that without issue, flushed the trans and coolant system a couple times and put it out to work. we put about 250-300hrs on it and started running into transmission troubles . The operator was complaining that it would drop out gears when articulating one direction but not with everything straight. He had also noticed that the inching clutch was at the top of its stroke. He was able to work it for about another 20hrs fine without articulating to finish up the project and then it was returned to our shop. He said anytime the machine did cut out he would just stop for a while, shut the master switch off and then it would come back on again and all gears would work.
This is when everything started getting messy.
I hoped in the machine and drove it around, nothing seemed to be the matter with it even articulating the machine it was 100% fine. However the inching pedal was at the top of the stroke only the last 1/8th of pedal play would engage the gear. We do not have the Cat ET software so I hired a mechanic to come calibrate the clutch. He did and said everything seemed good. I went to pull it out of the shop and we all of a sudden have no reverse gears at all but full engagement of all forward gears. We check all the wiring at the back and seems like we are getting solenoids engaging when they shouldn't be. OK MUST BE WIRING. check the harness from ECM to back, everythings good no cross continuity or broken wires. Check the sub harness and nothing everything is good. Get the mechanic with CAT ET software back and as we have an active code now. The codes coming up are both output speed sensors. He also says everything in the shifter is good(verified CAT ET shows it going thru all gears) but there is an intermittent break in solenoid #5 wire from ECU to solenoid. He tells us we have full pressure at all the solenoids but since its not going anywhere it must be worn out clutches.
We purchase the CAT service manual and pull the trans out, go through the clutch packs and sure enough the rear clutches are burned right out. Follow all the instructions, everything goes smooth and we get the transmission back together and in the machine. Go to drive the machine out of the shop and it goes in forward fine, reverse has only a couple gears. Drive it around some more and then soon enough we have NO GEARS AT ALL. Push it back in the shop and call the local CAT dealer. Thinking it maybe the ECM now. They come out install a test ECM and are able to drive it in some gears but not all, says its intermittent but not the ECM, must be something we've done in the tranny(they obviously want the work and don't put much effort into helping us figure out whats wrong, just tell us to drop it off and they will fix it). He also said that our serial number group falls into a range that has had issues with the manifold on the side of the trans cracking internally and that we should inspect that.
We take apart the manifold and find nothing. Drive it out of the shop have somewhat 1st gear, somewhat 2nd gear, then nothing, some reverse gears work fully and some don't work at all. then no gears at all and we have to push it back into the shop. We decided to replace the wiring harness from ECM to solenoids and that is how it sits. Still doesn't pickup any gear and still has the error code for the output speed sensors.
Not sure what to think, it must be something inside the trans but its hard to believe as the gears sometimes work great and other times don't work at all. Does anyone here have good knowledge of the inner workings of the transmissions on these machines? I'd like to know if there is something that could be sticking or bypassing oil that is causing the issue. Its hard to justify paying the Cat dealer 40k + for a transmission rebuild. I am not even sure if they do this if it will even fix the issue. I think it could be something else completely as our problem has never really gone away. I am thinking the reverse clutches have been worn out because of half engagement at times.
Sorry for the long post. this has been dragging out a couple months now and its getting hard to remember but I should be able to answer any questions.
S/N: ASD00346
Background story:
S/N: ASD00346
