Well Willis, I hate to tell ya this, but the words "simple" and "Bobcat" won't work in the same sentence. :tong
No power at fuse box, no power at key switch or BICS panel, you need to start at the battery, of course you already knew that. But look closely at the stud than connects ground wires to the ground terminal of battery. Once you have confirmed ground wires are in good order, check the positive wiring.
There should be a good size gauge, maybe 10 ga, wire that comes off the positive battery terminal and goes to a master fuse, located in a small black plastic box, just above the battery. Make sure positive voltage is traveling through the master fuse and continuing out the other side.
Check the positive wiring connections at the starter, where the positive battery cable connects, there should be two, maybe three, other power wires connect to that terminal on starter. I once had a Bobcat doing goofy things, discovered one of those power wires had a bad crimp on the wire. Had good voltage on the terminal, but probe the wire just after leaving terminal and it was dead.
If you've determined all this is good, pull the fuse panel out and confirm the power supply wire going to it is dead. If it is, you're, sadly, likely going to have to run down the main harness coming from the battery compartment, that big red wire at that master fuse. Bobcat did something really stupid in that harness, they sent that big wire into the harness, then before it terminates somewhere, they split that wire into separate circuits, within the harness, to feed power to fuse box, ECU, etc.
I'm hoping it's something way more simple than digging into that harness. Remember, like I said, simple and Bobcat don't work in the same sentence.
Keep us posted.
