JTWAT
Have a 2000 Sterling LT9500. Brake adjustment keeps backing off. Removed one of the slack adjusters that was not holding.
It is a Gunite type with 5.5" length. Question is: I measured the distance between center of S cam shaft and the pin in the chamber shaft and it's 6". Called Freightliner and gave them the VIN., they say it should be 5.5". So which length should I use? Confused!
