crane operator
Premier.
That's quite the hitch manufacturer. They make hitches for the trailer companies?
Premier.
I was looking at the thickness of it on my dump truck versus the thickness of the hitch plate I fabricated my traveling house, I went way overboard. Going to unbolt it and mount it on the dump truck, I'm sure it will fit. Don't see a half inch thick plate of steel holding over 20k lbs.that is one of those places where something being overbuilt is a great thing, not a waste.
IF you think you ever might pull a lighter trailer behind the truck, weld on a 2.5" receiver when you do the new plate. That and an electric controller lets you pull anything. I did it on my truck and it is very handy. Much better than loading my mini on the 20 ton. Here you can see that compensator that closes with air against the side of the big pintle.
View attachment 261481 View attachment 261480
on the dump truck it is all welded and knife plated on the back. It is not just a plate hanging out there oilcanning with the loads.
IF you look at that hitch on my truck, that trailer I have behind it would not fit at all on a big pintle. The ring is too small it is only a 7 ton trailer. With the 2.5" receiver added on, you can tow anything else.
pac pride canyon rdIF you think you ever might pull a lighter trailer behind the truck, weld on a 2.5" receiver when you do the new plate. That and an electric controller lets you pull anything. I did it on my truck and it is very handy. Much better than loading my mini on the 20 ton. Here you can see that compensator that closes with air against the side of the big pintle.
I received the KW with a four bolt pattern at rear,
Gonna STAY that way!! IF get a REAL trailer will get a Teflon Sheet plate pad for it. Goose pin will seat in at jaw pivot pins recess.Fifth wheel looks kind of dry.
