Georgia Iron
- Joined
- May 6, 2012
- Messages
- 877
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
Trailer has 2 axles with 2 tires on each side of each axle for a total of eight tires. I managed to blow both tires on one side of the front axle on my 20 ton trailer. I was loaded with about 35,000 lbs and it was raining. I was not able to pull over and continued with the haul. Oil is now leaking out of the inner wheel hub on the side of the trailer that was across from the damaged tires and wheels.
I let the trailer sit over night and found a fair amount of gear oil coming out of the side with the undamaged wheels and tires. Put new tires and wheels on and it is still leaking. I know I have damage, at this point not sure what. I was wondering if anyone else has occurred damage like this. I am wondering if the axle could have bent slightly or if the bearings might be the cause.
Anyone here had any damage like this?
