walkerv
If you aren't sure what your doing 550$ is a fair rate plus's the seals. They aren't terrible to replace it's mostly a pain getting to them.make sure your cab is clean as the doghouse will have to come out . If this doesn't at least slow down your oil loss then it will be an injector leaking internally as stated by someone else in your post. There is no way to tell which one it is doing it you will be forced to replace all 6 of them. I have good luck with alliant power aftermarket and bad luck with OEM remans
