Update, the block heater doesn't seem to be working at all. so it must be the element.
@kshansen Hello, do you have any info on these? This is a factory installed block heater. Thanks
Not sure if Cat lists spec's on the block heater elements, I'll have to take a look later, but the ones we had on out somewhat bigger machines always tested around 9 to 10 ohms when measuring across the two pins the cable slips over. Also just to be safe I always also checked from each pin to a good ground on the engine block. There you should have infinite ohms/open no conduction at all!
I would expect your's to be somewhere in that same range.
Well could not find anything for you machine but found one machine where it gave some spec's that one was a 1,000 watt heater where ours were 1500 watt heaters. So then I went to a ZeroStart online catalog and looked up what the suggest for a 3054 Cat engine which is what I believe you have. They show one rated at 600watts.
So next you go back to high-school science class and do some work with OHMS LAW, well actually I did cheat and find an online calculator!
Punch in the 120 volts and the 1500 watt of ours and it comes up with 9.6 ohms very close to what I remembered.
Next punched in the 600 watt rating for the Zero Start 3054 heater and it comes out to 24 ohms. So that is what I wold expect to see on yours.
Now if by chance your's is rated at 750 watts then 19.2 ohms
And if anyone has one of the 1,000 watt heaters they should show 14.4 ohms
