1997 volvo a25c trans problem
truecountry
clarksville va
Shop Manager and Tech
I have Volvo a25c 6x6 and it just started having transmission problems going into forward or reverse ...If it does go into gear to will run and shift though gears till you let off throttle and its back in neutral ,,,,
Only way to get it back into gear is shut it off restart
sfrs4
Great Britian
parts admin
as daft as it sounds,have you tried replacing the ignition barrel?
JDOFMEMI
SoCal
Another thing to check is the voltage. If you get a drop in voltage, the trans will sometimes not act right.
Check the alternator output. It may be getting enough juice when the rpm's are up, then not enough at idle.
After that, check the shift tower. That is a common failure. Especially if it gets parked with the windows open. The circuit board does not like to be wet.
truecountry
clarksville va
Thank both of you I saw Sfrs4 first after I had taken floor board up and disconnected air lines to brake pedals so I could see wiring better and feel it run thur my hands for brittle or worn places ...I checked switch and back half was lose and did a slow turn with meter hooked up and saw voltage drop and pick up maybe 2 mms turn I heard relays clicking and moved key switch back nothing ...Thanks Guys
sfrs4
Great Britian
parts admin
^^^^same here, you'd be supprised how many faults on transmissions and other faults on A25C's can be traced back to the ignition!
truecountry
clarksville va
Switch came in at quitting time today so I didn't get to try it ,,,,
Got a call from Volvo 2 times yesterday and again this evening from service Manager asking if I needed any help ....Then he procedes to tell me trans needs sensors inside and etc ..
I just asked him if ignition switch could be problem and he wouldn't say ....
Hopes this will do it , we need it rolling tomorrow
Mark10
Glasgow, Scotland
Plant Mechanic
Just had the same fault on a 35c traced it back to the ignition barrel. Would only take a gear sometimes and if you played about with the key it would work then.
truecountry
clarksville va
guessing the key switch kept the trans shifting and slipping and tore it out from voltage drop to sensors
truecountry
clarksville va
I ended up droping trans filter and it was loaded with metal big time
sfrs4
Great Britian
parts admin
Need Volvo a25c manual
If you are wanting a service manual, best place is online and take a risk with the virus ridden stuff they pedal on there, or get some deep pockets and pay Volvo for one.
