92U 3406
Still, its a lateral move in my mind. Swapping an old cab for an old cab.
Either that or spend 65,000 for another that's old.Still, its a lateral move in my mind. Swapping an old cab for an old cab.
That's interesting-I called Pete in Pasco with a vin from 92--No can do I was told.I know you phoned the dealer already but cab harness pn is 16-06274.
It was shipped with a PEEC 4CK24317 at 425hp.
For a cab harness part number or serial number of the motor it shipped with?That's interesting-I called Pete in Pasco with a vin from 92--No can do I was told.
I called back to Pete with that number-It is available-{Cab Harness my cost $3,813.00 onlyFor a cab harness part number or serial number of the motor it shipped with?
Should be able to find both even going back to the 80s. Cab harness may not actually be available on a older one.
As you are well aware most parts people these days are sub standard. Some of them just dont care at all.I called back to Pete with that number-It is available-{Cab Harness my cost $3,813.00 only
one available in Louisiana}. I'm surprised-but I don't think they wanted to look it up or
knew how the first time I called with a vin number, wouldn't be the first time. That price
is a fleet price from my old job, so it's higher than that plus that didn't include a fuse panel.
Built/made as ordered for a price.
Thank you for clarifying I am all mechanical now. This helped me have a little more direction in understanding what I was looking at with the engine cabling that pulled back and tied off. It must have been what went to the old fuel pump governor.Yes that's a manual injection pump. About a 95% chance it was Holst.
This is my and the mechanic's we hire out to main concern. I don't necessarily disagree with you in principle on the repair either. We'll still have an old truck. However, my name isn't on the side of the pickup trucks and the owner has a serious case of hoarder syndrome or whatever it is that makes a man hold onto things too long.... If you've seen some of my older posts our outfit runs a lot of older "well-loved" equipment most of which was well wornPersonally I wouldn't waste my time putting a 30 year old wiring harness into the truck. Just asking for endless electrical problems. I'd either go new or junk the truck.
You are correct, everyone I have called has told me they'd happily sell the cab minus the doors but that is the limit to what they are willing to pull out or sell individually.He's looking at replacing the entire cab, dismantlers won't part out a cab or sell in many cases
the harness from one only on rare occasions. Pete won't custom build a harness back that many
years. I don't know any manufactures that do. About the only thing they continue to supply
is a distribution box/fuse panel.
It's one of the issues that can happen running older equipment to stay away from emissions.
From $3000 to $6000 depending on the shape they're in.How much are cabs looking to be?
THANK YOU FOR SENDING THIS!Corrosion from people installing windshields with no sealant corrodes out most older pete fuseboxes. Done a lot of burnt wiring harness replacements on older 379s, usually in the engine compartment though. Just did a 2022 389 cab harness that burn out from driver installed chicken lights rammed into the hot side of the fuseboard.
I would rather bite the 6g and put a dash harness in it. The harness will have a couple jumpers and extra circuits plugged in that arent part of the main harness so make sure to match both of them up when it is on the floor.
Attached the harness drawing, schematic, and fuse panel repair parts if you wanna get creative.
I've been holding off on this, but you might try {www.mawkindustries.com}. For possibly building/16-06204 & 16-06205 are not available anywhere best I can find
And yes the risk with the older equipment, as I am now very well familiarized with, is parts availability.
