RockyHillRanch
Going to look at a 455GTC and have some questions. I have never operated a dozer before, however, i have operated many other types of equipment over the years. This will be used on a ranch to clear cedar, build roads, expand/build ponds, like quarry blocks, etc.
Is there a good reason that a ranch dozer needs to be TC or direct drive? does it matter for the low hour, low load use it will be doing?
The one thing i can pick out from the pictures is that one of the track tensioners seems to be leaking grease. Can see the grease pile and the track is looser than the other. How difficult is this to get to?
How hard are these to work on? I have always been a shade tree mechanic but will this require a completley new set of knowledge?
The tracks seem quite loud in the videos, is there something to check that would be obvious?
Is there 455gtc specfiic issues to look for?
Any and all opinions are welcomed. I will be going by to look at it because i will be in the area. If i don't see anything obviously wrong i will get a mechanic to look it over. Assuming it is in not terrible condition, what would you expect the price to be? 1989 with 4100 hours.
Thanks
Thanks
