1989 cat 963 Won’t move
Mross823
Missouri
Hey just trying to get a base of information before I get to crazy into diag,
I recently bought a 963 cat track loader, I bought it inop and got it running, after replacing hoses and a good bath I’m ready to tackle the moving portion, when I fire it up I have all hydraulic function and when I go to move the hydrostat I can hear the pump start to whine like it’s trying to move, but it’s frozen in place. Oil looks full and good, and there are no obvious leaks. Almost seems like the break is stuck on, going to check pressures this week when I get off work just looking for some quick insight. Bought a full service manual for it and doesn’t say much about my certain issue any insight is helpful thank you (picture of machine and serial number below)
pittsburgh cat man
saltsburg pa
The first thing to do is pull up the brake pedal make sure it is up the whole way if it is up the whole way check the brake lever on hystat there is a hole in it a 5/16 course bolt should be able to screw into with no problem they way you are talking it sounds like brake pedal is stuck down kind of normal occurrence with open rops
Mross823
Missouri
Mross823
Missouri
I think you've been had. Unless you paid North of five hundred bucks for it what you got wasn't genuine.
See that link I posted above for a genuine used manual. They are about a grand new.
The one you sent doesn’t cover my SN I don’t think it says 21Z1-up where mine is a 21z0 unless I’m reading my tag wrong
