jrosperich
I purchased an 88 highlander a week ago and it ran fine for a few days with a little bit of struggle to get fired up. I got it started 2 days ago and it immediately shut down. Checked the fuel tank and topped it off, went back to try starting it again and it wouldn't even attempt to turn over. I checked the battery, still had a charge, put a lot tester on the starter and I wasn't receiving power. I replaced the ignition switch, took the starter to auto zone for testing and it works fine, checked the fuses, all intact but had a ton of corrosion around them, which I cleaned thoroughly, still no response whatsoever when I turn the key. I'm not sure what else could be going wrong. Wiring all seems to be in decent shape as well.
