sotted
Good afternoon all,
I own a 1983 JCB3CX, when you slew in the left direction the machine operates correctly, when you slew right the arm moves extremly slow and will not move with any load. If you extend or retracted the boom or bucket to a point where it is bypassing at the valve (and hold it bypassing) then the slew will function correctly. I have swapped the bypass spools ( i think they call them ARVs?) between the left and right direction, but nothing has changed. i have increased the distance that the control lever pushes into the valve block, no difference? has anyone ever had this problem or can anyone point me in the right direction? Any help would be much appreciated
Thank you
Thank you
