1979 444 Case Tractor 5/8” 37°double flair fitting
Sportsman762
USA
Ridgid 377 or Imperial 400F are good flaring tools. The Ridgid has a clutch so your less likely to overwork the pipe. Use a Parker BX nut with a TX sleeve or an Eaton 1290 nut with a 900605 sleeve. According to Parker the 212FB is for "soft metal tube ends" "For use with copper and aluminum alloy tube in sizes 1/8” through 3/4” O.D." Not that it would not work. Just not recommended by Parker.
  • Like
Reactions: DB2
Sportsman762
USA
I made an error in my prior post. The equipment and tools I listed are for a 37 degree single flare for use with JIC fittings. If a double or bubble flare is needed it will use different tools. However I am not aware of any older tractors utilizing those flares. Normally they are a JIC.
