dbs
Sure sounds like you have a suction leak dbs. That would explain the filter being half full.Could be anywhere from the pump back to the drop tube in the tank.Dont know what setup you have ,I have a 1973 white 4000 with 290 small cam and it uses a remote filter bolted to the truck frame .Also have a 1974 pete with a 300 big cam and it has the filter on the pump.On both trucks at the back of the pump are some capscrews that hold the filter base to the pump like on the pete,and on the white the same screws hold a threaded plate for the suction line the go's to the remote filter base.Got to thinking about this thread today......I might try snugging up the capscrews then work your way back to the tank.I've never seen these screws cause trouble in the past but anything is possible.
I talked to the cummins dealer today he reported the there is a check valve on the pump that can go bad so I'll be checking that to see if that was the culprit.
