Jack1
Hello to everyone on this forum'
I was wondering if I could get some help here' I have a 1974 King International Harvester Firetruck and I was driving it up one of my hilly roads and it was low on Diesel fuel' It quite on me half way up the hill and now it won't start' I filled the tank up with diesel fuel but now it has air in the system. This truck does not have a primer pump and I can't see the fuel rails or injectors on this motor so I can't crack the lines at the injectors to let out the air. One thing I know I have against me is it's half way up a hill so the fuel tank is lower then the motor. What I have tried is sucking the fuel up to the two fuel filters and I tried pumping fuel up the line to the pump. I filled both fuel filters and cranked it over about 4 times and then fill the filters again and crank it over. I did this about 15 times' when I first crank it over it tries to start for a second and then just cranks. There has to be air still in the lines but I can't see the injectors to crack the line to let on the air. Is there an easier way to do it because I don't know what to do now.
Any help would be appreciated.
Thanks, Jack
Thanks, Jack
