1974 ford 5000 quit running
kavarsee
lawrenceburg,ky
Has CAV injector pump
Out mowing yesterday-suddenly quit Has fuel, fuel getting to pump-will run out of bleeder.
Anyone know wha is most likely to break?
Tractor always started quickly, ran well, no excessive smoke or misfiring; no signs or warning of impending failure
Thank You!
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I don't know this tractor specifically but will try to help. Does it have a fuel solenoid? If so, you would shut the tractor off with the key instead of pulling a knob. If you do have a solenoid this is the first place I'd start looking, see if it is being properly energized with ignition on. Then check that fuel will flow through it while energized. If there is no solenoid none of this applies but it's the simplest place to start.
Could be the drive to the injector pump, that's going to be a lot more difficult.
