Leon Phelps
Hello,
Trying to get the pin out of the lift cylinder for a 1971 CK. I am figuring to remove the pin then tilt the piston forward then get the rod out to replace seal.
here is a photo of the pin I need to drive out. I have tried it from both ways and it is a solid ping, like it is on there good. I forget if I can only drive it one way or the other.
photo can be seen at https://lh5.googleusercontent.com/-n5zqJjVpTYY/T2ElAXDaXDI/AAAAAAAAHaE/FAzFMy3Hmvo/s800/100_3054.JPG
The import image will not work for the site.
Any suggestion for how to remove would be appreciated.
