mopar
just curious as to what parts are interchangeable from a 530CK to the 580ck?
sorry I should have been a little clearer. I am not concerned about the backhoeI'm not sure, I do know the backhoes are different the 530 has a 31 backhoe and the 580 has a 33 backhoe. What parts are you interested in exchanging?
sorry I should of been a little clearer. I am not actually concerned about the hoe part. I have a 580 I want to get running and have a chance to pick up a 530 quite cheap just for parts. so that is why I was asking if most of the power train parts would interchange?I'm not sure, I do know the backhoes are different the 530 has a 31 backhoe and the 580 has a 33 backhoe. What parts are you interested in exchanging?
ok thanks so much its nice to know at least some parts if not worn may be useful, always good to have a parts source to rob from.If both engines are diesel they should be basically the same. Power steering should be the same also. I believe the hyd. pump is different because it runs off the PTO shaft on the 530. You can do a parts search for any common parts at www.partstore.casece.com just look up the 530 or 580 and 31 or 33 backhoe.
