I have the 323e with about 1600 hours. Serial number 1T0323EMVHJ322974. Since I have had the Machince it has had the code ecu 412.03 exhaust gas temp 1 1665.1
And 2 1666.2
When I would track the Machince it would drop from 2700 to 2200 rpm’s but still had good hydraulic power when it came to lifting and moving.
The other day I was moving dirt and a new code came up that said hydraulic temp out of range and the fan cut on high but soon went away. I looked to see what the temp was reading and it was -33 degrees. After that happened though the machine didn’t have hardly any power at all. Barely moves, can hardly turn and lift. I deleted the codes but it didn’t change how the machine works now. Can someone help
And 2 1666.2
