charles walton
I am wanting to put 235/75/17.5 tires on my tilt tag trailer in place of 8.25/15.00 tube type. I have ran some 215/75/17.5 with the spacers,will the same spacers work with the 235's or will they be too close?
I guess nobody knows anything about this.I am wanting to put 235/75/17.5 tires on my tilt tag trailer in place of 8.25/15.00 tube type. I have ran some 215/75/17.5 with the spacers,will the same spacers work with the 235's or will they be too close?
Looks like maybe a 1/2 inch wider will work. I'm going to get 2 tires mounted up and try it with the spacers that I have and see if they're too close. I was hoping someone could tell me what width they were using in this application.Assuming spoke hubs, if you change the spacer to wider, how will you get the clamps on?
I picked these rims up with some 215 tires that won't meet my application so I'm going to take them off and put new 235's on and I won't stress over it.If you have rims for the conversion you would be good. I've done what you propose and had enough clearance. You should currently have 3.50" length studs and these are easily replaced by 4.00" if needed for wider spacers.
If you are going to work with a vendor for the 17.5" rims, ask if there would be a discount per rim available for quantity. I need eight of the 6.75X17.5 to convert my old trailer over also. I already have new tires but no rims to mount them on yet.
