16M in the Arctic
Randy Krieg
Arizona
Test Pilot/Operator @ Caterpillar's Tucson Proving
Just home for my 2 weeks R&R and thought I would let those interested know how this unit is handling the extreme cold. The machine is being used to build and maintain Iceroads on Chevron’s White Hills Project. This project is located approximately 200 miles north of the Arctic Circle in the interior of Alaska.
Overall performance of the machine has been very good. We still have some steering control warnings to deal with, anytime the temperatures or wind chills start getting down around -40 degrees you can set the “Lose of Steering Control” alarm off by simply attempting to steer quickly. Due to extremely cold oil it is easy to out run the positioning sensors in the steering cylinders with the Joystick. Due to 2 -12 hour shifts and the 2 week on 2 week off schedule three other operators and I operate the machine. We all have varying opinions on the machine. I personally enjoy it very much for the type of work we are doing right now. It is very user friendly and extremely comfortable. I still believe they should have extended the mainframe another foot (between the cab and lift cylinder mounts) and gotten the moldboard out from under the cab. We have an 18 foot moldboard and with that the G’s were too short, the H’s were too short and now the M’s are still too short. I would also like to see 5 more degrees of articulation. I would gladly give up a little turning radius for some steeper moldboard angles and still see the heal of the moldboard.
Here are a few shots of a blow closing in on me. At times it gets so bad you can barely see the ripper bar in the rear view mirror. This is when you start praying that you don’t run out of fuel. 50 to 70 below wind chills, you wouldn’t last long.
JTL
Pacific Nortwest U.S.A.
IUOE Local 302
40 below! And to think I was complaining about 15 below!
Nice to see your still around, Randy. I knew if the new M had any faults at all, you would point em out!
Take care and stay warm.
Jason
Northart
Talkeetna, Alaska
M Series
Hi Randy,
Glad to hear from you on the Cat 16M .
Your right about the moldboard being under the cab. (14M) Took me awhile to realize the sight angle had changed. It became steeper. I thought I had the seat too far forward .
I was going to measure it, and see what the difference was on the 14H and the 14M .
The heel is obstructed by the cab door frame. I had to move the center shift out and use a lessor moldboard angle.
How's the fuel doing ? I heard from a friend that 98 vehicles were down, the other day, for fuel gelling on the Slope. They said it was only -27F at that. They were blaming the new ULSD fuel that became effective Jan 1st.
Later, Northart
EZ TRBO
USA
Aggregate Utility, Maintence Welder
Very nice pics. It goes to show you that no matter how much engineering is done on a machine every operator is different and when you make one thing really good it usually hinders(even if slighty) somthing else that was near perfect on the series before. The dirt crew foreman at the highway shop has his choice of which grader he runs during the winter for plowing, and he always takes the oldest one in the shop. Says he is used to it and enjoys pushing snow with the old work horse.
Trbo
milling_drum
out west lately
asphalt mill operator (ret)
Thanks for the pictures and machine details.
How do you people know the road area in a white out? got GPS?
surfer-joe
Arizona
Company I worked for some years ago had the first 16G's on the slope and they had the same problem with the steering. The problem being of course, the the hoses and steering cylinders are so far out that the oil never gets warm enough to do much more than crawl slowly thorough the lines, "kinda like toothpaste," is the way one of the old Alaska hands put it to me. They did not have the advantage then of the newer arctic oils and fluids and really had a tough time getting some machines to operate well in the extreme cold. I had the same problem in Northern Ontario one winter with slashers and 14G's.
A guy I worked with in Colorado, got trapped for three days in a 992C in a whiteout at the Red Dog Mine in Alaska one winter. No one could get to him and he couldn't get out, was afraid to even leave the cab. Fortunately he had a large water jug with him and he had packed some extra food in his lunch bucket. He said it wasn't the first time he had been caught in the pit in a blizzard, and he mentioned that they came in fast. He was lucky that 92 kept purring away.
Northart
Talkeetna, Alaska
White Outs ?
Hello Surferjoe,
With all due respect, for your status , I think the previous story of the Red Dog Mine Loader Pit escapade, is far, far, baloney !
3 days , pure BS !
I worked in the Arctic (PET-4) in the '70's and '80's , long before modern GPS .Before Red Dog was ever conceived ! Yes, we encountered many white outs, . No one was ever, ever, stranded by negligence or design !
DPete
Central Ca.
Cool pics ( literally) how about some more pics of what you're doing up there when you go back? Us fair weather guys don't like 40 above can't imagine -60
surfer-joe
Arizona
Hey Northart. It was his story and I passed it along for what it was worth. Having been involved in some bad blizzards myself at times and also having worked closely with many people with experience all over Alaska with similar blizzard and whiteout experiences, I had no real reason to doubt him as he wasn't prone to exaggeration.
Many people I knew from my employment with the old Green Construction Company related similar incidents from their days working in Alaska on the pipeline and north slope. What they had to do in order to work in cold conditions and bad weather are riveting stories in themselves, particularly in light of the fact that they were using some equipment never intended to work in such climatic conditions.
The Green people worked particularly close with Caterpillar and other manufacturers to develop new and better lubricants and methods to combat the cold and extreme conditions, the 16 motor graders are a case in point. Green had two or three of the first production G models ever built and one of them was in Alaska. I had one in Wyoming just after it was completely overhauled and updated by Cat. The factory monitored these machines closely.
As for blizzards and whiteouts, the closest I ever get to them now a days is watching them on the telly. We get bad dust storms here, in fact my last RV haul in October was right in the middle of a bad one, but they don't compare to a long whiteout.
Stay warm and dry up there buddy, if you ever decide to get out and come to sunny Arizona, look me up.
Grader4me
New Brunswick, Canada
I don't care what the conditions are...for a chance to operate something like that..I for one would take the chance..brrr..Thanks for the great pictures!
Randy Krieg
Arizona
Cool
Wow lots of questions to answer and comments to make. In regards to the pictures I’ll add a couple more at the end of this to help explain what I writing about. I’m planning to purchase a new camera on this trip home since the one I’m using now has only 2.0 mega pixels. Easy to carry, but not really spectacular pictures.
Art we have not experienced any fuel problems yet. They did shut down a couple of Case Tractors/Snow blowers because they weren’t being used for a couple days, which was a foolish mistake. Suddenly the blow comes, the next day we needed them to cleanup and they couldn’t get them going. Took all day with Thermon’s and parchutes to get them going.
I have included a picture of the 16M working with one of the Case Blowers. Also pictures of building the drilling pad 600’x 600’, the area where the drill sits is 300’x 300’ and the ice had to be a minimum of 3’ foot thick to support the rig. The rest of the pad is camps, tank farm and drilling mud containment area. The rig was just arriving when I went on my R&R, but I have included a picture from the same drill rig, which my son took last year. Other pictures are of the Tundra Bears (730 Cat Articulated Trucks converted to LGP Lowboy), these rigs bring in the supplies and groceries. Other picture is the fuel train passing me on the Iceroad (Case/Stieger Tractors towing fuel tanks and a drag) They actually run right beside the Iceroad in the snow for better traction. Another picture helps answer the question of how we get back to camp, shows the Carsonite Markers. Just like on the highway they use white on the right and amber on the left. On tangent sections they are placed 200 ft apart on the same side of the road and are staggered so the one on the left is only 100’ from the one on the right, in the corners or curve they tighten up the spacing depending on how tight the radius is. If the blow gets really bad and you’re in a team you stop at each marker, the lead vehicle then proceeds to the next marker while the others wait, once he finds it then he radios to the others to come forward. Then when it gets so bad that’s not working a Tucker quadtrack with GPS/and a DTM file of the Iceroad comes out and picks you up. You turn your machine inline with the wind set the idle up and leave it. Several operators carry their own handheld Garmins. They have also purchased several new locator beacons and are making plans to install them. The 16M has Caterpillar Product Link and the dealer has been monitoring the machine from Anchorage. There are also milepost signs every mile so you can tell the Tucker Drivers your location if they have to rescue you. There is also a “Journey Manager” on call 24 hours a days at mile 0/Franklin Bluffs. Every 5 miles there is a big red “Radio Check” sign to remind us to call in our location. Journey Manager has 4 radios in his office; 1 is for the crews maintaining the Iceroad, 2 is for the crew building the iceroad and drill/camp pads, 3 is Franklin Bluffs Base Channel and 4 is for trucks traveling the Iceroad moving supplies and drill components. Safety on this project is second to none; they really are going all out to keep us as safe as possible.
It’s very reassuring since my oldest son runs the GPS Rover on this project and does all our grade checking.
In regards to the “Iceroad Truckers” TV show, they approached the company last year about doing a segment on our project. I don’t know if it will ever happen. In regards to women on equipment, I know some darn good female operators. One of the 740 Ejector Trucks on this project is run by a very capable lady. I also date a lady who is a great operator, very qualified. The days of this being a man’s world are long gone in my opinion. Thank Goodness!!!!!LOL….
stretch
Southington, CT
gopher
Great pics Randy! You guys who work on the Slope and up north sure keep impressing me with what happens up there. :drinkup I like the 740 with the lowboy.
special tool
Bethel, Ct.
Randy - I am genuinely interested to know why this machine is affected by wind chill, and not just ambient.
Thank you for any info.
hvy 1ton
Lawrence, KS
Do you have you have any more info on the tundra bears, can't find much on the net. I've always had a thing for arctic operations, especaily on the slope and at the other pole. Any more info or links would be cool.:drinkup
ovrszd
Missouri
Retired Army
Awesome thread. Thanks for posting Randy. I've been on some pretty wild adventures but nothing in the Arctic. Keep sending info and pics.
Randy Krieg
Arizona
DPete.......
I meant to post these pictures the other day to answer your question about what all we’re doing, but had to take off.
We haul snow off of designated lakes and water from designated lakes. This is all controlled and regulated by Alaska Department of Natural Resources (DNR). Lakes, which are up on the higher plateaus and don’t collect as much run off are highly regulated and we can only take a designated amount. Lakes in lower areas and closer to the rivers we are allowed to take lot more from. All of the drivers are required to fill out a DNR load sheet each day so the Project Managers can report to DNR how much water is being taken from each lake. During Ice road and Pad construction we are basically mixing water and snow with the motor graders to make Ice. Different temperatures require different mixing ratios. I finished the grade on the first drilling and camp pads with our 14H equipped with Trimble GCS600 and controlled it off a Trimble RL700 Dual Plane Laser. This is the first pad that has been finished using automatics on North Slope. Chevron’s Company Man said it’s the best drilling pad he has ever seen. Many people told me this couldn’t be done, but we just set a new standard for this. We had some issues with cold weather and the Automatics, but were able to work through them. I have other plans to help the system for finishing the next pad when I return.
Randy Krieg
Arizona
One more Pic
Some time today or tonight I will start other thread under another catagory to answer the T Bear question and post some other photos and answer the wind chill question. Right now I gotta go plow some snow.............................
Randy Krieg
Arizona
Special Tool
Wind chill or just the wind period works exactly like the fan behind a radiator. Though wind chill can never cool any live component (hydraulics, trans engine) down lower than the ambient temperature it will cool it down faster. Hence the problem with the long steering hoses on the motor graders. Any heat generated from the pump, which is absorbed by the oil is quickly carried away once the oil enters the lines, the cold air blowing across the line cools them down almost instantly. A vehicle shut off at -30 and 20 knot winds cools down much quicker than one shut down at -30 with no wind. The wind finds its way through the smallest crack, it’s actually amazing. I’ve seen cabs nearly filled full of snow because operators parked the machine facing the wind with a leaky door seal. You only make the mistake once.
One other note on the steering hoses and cylinders on the G, H and M series graders. The volume of hydraulic oil held in the lines is greater than the volume held in the barrel end of the cylinder when fully extended. So warm oil can never actually get from the tank to the cylinder. This is why they install jumper lines on the cylinders at the factory to force all the air out of the lines and back to the tank where it can then be vent to atmosphere. It takes 22 full revolutions of the Hand Metering Unit (HMU) to displace the oil all the way down the line to the front of the machine through the jumper lines and back down the opposite line through the valve and into the tank. Once this is done the jumper lines are removed and plugs installed.
Regards, Randy
