140H Fault Code
gcshop
Ulysses, Ks
Shop Foreman
We have a 140H CCA02629 With a fault code of 036-0274.03. Can some tell where to search for the cause?
kshansen
Central New York, USA
First off that code is for "Atmospheric Pressure Sensor-Voltage Above Normal"
I'm attaching a couple files that might help figure this out and maybe others can point in a direction.
First is the wiring diagram:
Next is the Trouble Shooting Info I could find:
  • 140H RENR9556.pdf
  • 140H Motor Grader CCA00001-UP (MACHINE) Pressure sensor test.pdf
