140G transmission cable removal?
Mobiltech
Sask.
You have to take 2 bolts out of a plate that holds the 2 cable sleeves into the trans. When you pulls the sleeves out of the trans far enough they will unhook from the spool eyes. Then take the 5/8 jam nuts off at the sleeve and slide the cable thru it.
Mobiltech
Sask.
The sleeves have orings on and may pull out kinda hard.
