I have added 13.5 litters after 250 hrs to top up engine oil level.
A question. Did you add 13.5 litres at one time - 250 operating hours since the last engine oil change, or is the 13.5 litres the total quantity of "top-up" oil that was added during the 250-hour period.?
How often is the engine oil level checked and topped up if necessary.? It should be done daily.
As above, how many total hours are on the engine at this time.?
I'm sure that you have access to ET. I suggest that you should download a Product Status Report and look closely at the Engine ECM statistics for the percentage of Idle Time. In your climatic conditions this will be the time the engine spent working as a 200+ BHP air-conditioner to keep the operator cool.
The possibility exists that all the engine needs to "normlaize" the oil consumption is a bit of hard work..........
