120 AD3 Bomag Roller wobbling rear drum
Snatch
Montserrat
Civil Engineer/ Contractor
All,
I have just changed some hydraulic hoses for my Bomag 120 AD3 roller. We started to operate the machine and noticed that the back drum is wobbling and making a noise (grinding metal on metal). I was told that the problem is that the bushing for the rear drum needs replacing.
Has anyone ever experienced this senario. Are we on the correct path.
Looking forward to any response
Thanks
DW
chewy
il.
wobble
drums are mounted with rubber isolaters behind the large disc. look for the 5 nuts behind the drive mtr and behind the vib mtr. they will be broken. usualy from tieing down too tight for transport.
Drtdigger4
Searcy, ar
Mechanic, operator
I'm having this same problem with a roller right now. It blew a hydraulic line changed that line and the next one to it cause it was bout to blow too. After doing thing the drum is not vibrating. The machine itself is vibrating but not vibrating the drum. What did you find wrong with your roller any help is greatly appreciated I'm at loss at what's wrong with it
Thanks
