10 wt. motor oil substitute
If it was mine, and it's just the hydraulics, not transmission etc, then I'd just flush it and fill it with AW hydraulic fluid, or universal tractor fluid, just NOT 303. Pay at least $40/bucket.
DIYDAVE
MD
I think its called ISO-32 hydraulic oil, googled, to be sure...;)
Tenwheeler
Georgia
I have been meaning to see where I got my on line book from and get that to you but I have not. As I read the chart in my book there are many different weights of oil acceptable depending on temperature. I am running 30W.
g_man
Northeastern VT
Retired
I use Kendall Power Shift Fluid 10W in both trans and hydraulic tanks of Dresser TD7G. Get it at the the Komatsu dealer.
200lc1
BC Canada
Any opinions of using universal trans-hydraulic as a substitute for the 10w in a transmission? Can't quite get the manufacturer specs to line up, but same weight, similar properties, generally cheaper.
56wrench
alberta
there may be compatibility issues with any friction materials ( ie wet clutches etc ) . up here shell still makes rotella 10w
