If you actually have a Delco SI type "one wire" unit, it won't have the two terminal spade connector on the side of it. It should just have a ground screw and a B+ terminal. The B+ terminal goes to the battery. Next, to monitor your charging system, simply use a voltmeter.
On the other hand, if you have a regular run-of-the-mill, Delco 10si or 12si alternator, you will need to run a field circuit with an indicator lamp. Easy peazy. A quick google search will supply the wiring diagram. You might even be able to utilize your existing indicator lamp.
