Welcome to HEF axiswelding. :drinkup
Code 14-03 is a problem with the fuel shutoff solenoid pull coil. If it's popping the fuse when you turn on the ignition, likely the fuel solenoid is shorted out. Try disconnecting the harness connection at the fuel solenoid, then power up the machine, see if it still pops that fuse then. I'm thinking it may be popping that fuse as soon as you power it up, but once the solenoid is engaged you have no idea the fuse is blown until you try to start it again. You might want to look at it a little close and see if it is doing that. Replace the fuse, start it up, and see just when that fuse blows.
