buckhornspice
Was running good, shut down , next morn engine wouldn't hit a lick just turns over any suggestions besides a match
Did you check all fluid levels as it will shut down the engine for something like low coolant. I would think it would start first though and throw a code. Maybe you parked on an unlevel spot and the sensor is not reading right.
Give it a sniff of starting fluid to see if it'll try to fire. That'll tell you if it's fuel related. Maybe it sucked air into the fuel system(damn plastic fuel lines next to a hot engine) or bled back to the tanks overnight.
Seems like the 138 code is a generic code that it'll throw if your fluids are low.
