Scout_1969
My John Deere 310B backhoe (in order of severity) needs the crowd, both swing and one stabilizer cylinder rebuilt. I'd like some advice on removal, seal parts source and any other advice that would help. I helped repack a cylinder once and have done some online research, but have some questions to hopefully make the process smoother and not damage the rod guide.
Rod guide removal-
I’ve searched this site and online but any links, videos etc. would be appreciated.
Rod guide removal-
- leave cylinder on the machine
- the set screw is removed and I tap the barrel with a mallet several times, I'm unsure on the best method for unscrewing the guide to avoid damage.
- Some folks online use a punch, air chisel or pipe wrench for the old likely seized guides, newer ones use a spanner wrench.
- The vibration from the air chisel would have it's advantages.
- The spanner only grabs one slot so I don't expect to break the guide loose with it, just speed up unthreading/threading.
- I could heat the body if necessary.
- The pipe wrench would certainly scar the guide so that's a last resort.
- Is there a tool or could one be made to seat in at least two of the slots? This would spread the force over two slots instead of one.
- Of course the dealership is trustworthy but up to 4 times more costly over aftermarket
- Hercules
- Baum hydraulics
- Tornado
- Tractor parts ASAP
- Of course I like to save money but dont want to regret it
- Seals kits seem to have extra seals to cover several applications, would be nice to have only seals required.
- I plan to use a pvc pipe to place old removed seals on in order of removal to match new seals
