hougie
Anyone got the s650? Just got a new one on monday. Moved up from a 205. SJC controls with ac/radio/2speed etc. First thing i've noticed is that it doesn't track straight. What do you think of yours?
thought i'd give a bit of an update. Only thing bobcat didn't get right is the spacing for moving points. Squeeks a bit when going up and down. Maybe paint was a little to thick, which isn't a bad thing. Only has about 15 hours on it now
i greased it, then greased it again. And then i greased it once more haha. The squeeking is because the paint is either to thick or they didn't allow enough clearance.
LMFAO ! ...... bindare donedat ....... the grease is not a fix-all in your case either ....... my A-300 (at times) has done the same thing since new..... got 2800hrs on'er now and showing NO signs of excess wear anywhere ..... just one of those stupid things you gotta live with .... If I was to guess where, it would be in that smaller black stabilizer arm on both sides under the main boom ... jmho
Bought a used S650 with 3800hrs on it, wondering if someone can someone tell me if the S650 makes a bit of a growling hydraulic noise when in 2nd gear while turning? Doesn’t make any noise in first gear. Wondering if I should be concerned or not about it.
