No, we had done that prior running through a shuttle valve and it actually made it worse. Hard to believe it could be worse but it was.Did you have LS lines hooked to NFC lines while testing?
Then you are running little bit better then on stand by. You are running on stand by when you have pressure on NFC lines.No, we had done that prior running through a shuttle valve and it actually made it worse. Hard to believe it could be worse but it was.
So what you saying is that solenoid by the pumps have nothing to do with torque limiting and protecting engine from overloading by hydraulics?Standby pressure is a function on a closed center hydraulic system. This system is open center parallel passage. It is also negative control in that it only switches the pump on and off in the earlier versions and may have limited ability to regulate on this model. This machine as I recall has an H, S and L setting that is controlled by the mode switch in the control panel. That control went through the computer but didn't change by loads on the engine. A PRV is a component on a Caterpillar hydraulic pump. Link-Belt always called theirs a Main Pump Proportional Solenoid. It wasn't proportional at all. It had three milliamp readings that you took, one for H mode, one for S mode and one for L mode. The pump went to full output whenever a function was operated, limited only by the main pump proportional solenoid.
As I recall on these machines the option port is only single pump flow.
I think Gary has the right idea to get the pumps to stroke up.
The simple answer is that you cannot ask for too much.But the problem with this set up is that you have to use restriction only type of flow control, and not restriction/bypass type to still have flow for the rest of machine to use.
And then question still remains what kind of pressures you will be able to build up on the Right Pump side of the MCV, will the operation of the functions on that side be stable or unstable and intermittent, will the Right Side start to heat up and so on, so on...
For more convenience, we can use 02 pressure switches No. 25 and No. 40 to turn ON or OFF "dual flow solenoid" No. 11 automatically. It's not too difficult to do that, right??..When you need to use other operations, you have to disconnect right side pump (turn OFF "dual flow solenoid" No.11) , the lawn mower switches back to use left pump only.
Note that we already have a toggle switch for this function (to turn ON "dual flow solenoid" No.11 for combine flow of 2 pumps).
