Some of the information is clearer. Then I suspect that the lawn mower's control wiring has affected the wiring that controls the lock lever solenoid valve.I heard oil going through pilot control valves on some machines, last one was CAT 304 CR, it might not be normal, but it happens sometimes.
The mower DCV is D05/CETOP 5 solenoid controlled, so it is not needed pilot pressure from machine.
There’s also possibility of ECM cutting pumps flow through EPPRV when it reads engine RPMs drop but no function pressure switches ON, but I am not sure about that.
I'm confused by this 2 pump priority valve. What hammer(when matched to the machine) needs 2 pump flow? Now if its 2 pump bi-directional for a volume hungry implement, ok. Where is this priority valve? How's it plumbed?
Yeah! That’s the next thing I want to interrogate that guy on?!Some of the information is clearer. Then I suspect that the lawn mower's control wiring has affected the wiring that controls the lock lever solenoid valve.
This is CASE CX160 lever lock circuit, it's exactly like the LB160LX.
As every one can see....it's very..very..very simple one.
Well! The priority valve has LS port ( as well as G port for gauge) connected to a CF port, so it is basically reads mowers main pressure, but mowers DCV also has LS port which supposed to read the pressure on the “working” side of the spool to control just regular open loop piston pump like A10VO or Sauer Series 45, or Oil gear PVG ( that’s what mostly runs on forestry attachments) with LS controllers.And, I would think this priority acts as a control in that it generates LS signal to pumps? Is that correct.
I’m pretty sure it is straight to the tank!That and whether or not you need bi-directional flow, return through the control valve or straight to tank.
So if LB LX line similar to Case CX line - then LB Quantum line similar to Case 90**B?Some of the information is clearer. Then I suspect that the lawn mower's control wiring has affected the wiring that controls the lock lever solenoid valve.
There is no connection between pilot circuit and mower circuit!
Mower connected to main pumps through priority valve.
I am more inclined to thinking problem is in the main pumps flow. But need to make sure the pilot side is covered.
I am not about to pay for the machine manual just to find out if hydraulic shutdown solenoid is wired through ECM or not - that’s for the guy on the ground to do!
I know my question is a long shot, just was hoping that someone who is really knowledgeable in Link Belt would know this stuff.
From my understanding, your are connected straight to the mower through a priority valve from the pumps. There is a specific priority valve available from Case for these types of applications that require constant flow. I'm assuming you did not plumb the mower through the aux valve due to flow fluctuations. I believe you likely have a wrong priority valve installed (or miss adjusted) , and its messing with your pumps. Any pictures or part numbers available?
Well!That looks like a bunch of extra garbage when the auxiliary spool could have easily satisfied the needs of the implement. It's like it's own control valve . If the machine has a supposed 74 GPM available why couldn't one pump supply the 34 needed for the attachment? I always like to use factory add-ons where possible. I think a foot pedal control and the aux spool would have more than sufficient for his application. That also would reserve P2 for basic functions
I had an idea of pilot operated pressure reducing valves installed in to both NFC lines and adjusted just enough of NFC pressure drop to run the mower. Those will drop the pressure only when there will be a pressure signal from priority valve. For the same reason - didn’t want to push all the available flow through the system and overload!Typically diverters were on each pump for mower service as they didn't want all the flow coming from a single pump. That is what allows operation of the machine at the same time as the mower. Diverter valves have to have orifices installed to set the flow to the mower. That takes a flow meter and plenty of experimentation to set up.
On a negative flow control, you have to tee into the NC lines and dump it to tank in order to get the pumps to stroke up when running the mower. The problem is what little control that the NC does provide as far as load sensing is then gone as the pumps then try to over load the engine. Then you get to play around trying to find the right size orifice again to limit the amount of NC oil into the drain circuit.
As far as the pilot circuit goes, there is a pilot tie in at the pumps which is used as one of the balance functions in the pump control valves. That shouldn't affect anything else. That someone could hear pilot oil through the joy sticks indicates a plumbing problem. You can put a gauge on the pilot circuit and watch the pressure go away to check that. I've not worked on that series of Link-Belt and can't confirm if the system is Negative Control or not. It may be something totally different now.
