Volvo L120F Warning Brake Sys Failure
RMadilla
Overseas
US Air Force Vehicle Mechanic
I've got a 2009 Volvo L120F Loader that is throwing a Warning Brake System Failure message. Accumulators (new), Sensor SE5218, Solenoid MA5502 have all been swapped from a working loader we have in shop and it still hasn't solved the issue. We tested and measure the wiring from V-ECU to the sensors and solenoids (all within specified limits). Additionally my accumulator pressure is sitting around 1845 psi (I know its supposed to be above 1900, but it was at 1400 before I replaced the accumulators). I've bled the system, according to the service manual, and all my brake functions are working properly, and will pass a brake test. Any help is greatly appreciated.
RMadilla
Overseas
What is your fan speed? When operating does it over heat? Do you have a quick attachment?
Paul,
Fan speed I think is sitting around 440 RPMs, does not over heat, and no attachment just a plain bucket attachment(non-clamshell).
Thanks for the quick response!!
RMadilla
Overseas
Are you measuring pressure off the accumulator manifold or monitoring what SE5502 sees on the display?
Correction, my accumulator pressure is now at 2050 psi with engine running. I am providing readings from SE5218 being sent to operators display in service mode. That's how I provided the numbers in this post originally. I do not have a pressure gauge compatible with the system. We are quite limited on what's available at the moment. Fan RPMs are at 420-440 and I have adjusted the speed sensor to the correct depth (1 +/- .2 mm) but did not change anything. I feel like this is really low. What is the correct Fan RPMs supposed to be at? Am I able to adjust PWM2601 for fan pressure to control speed?
MA5502 is a solenoid though, not a pressure sensor.
RMadilla
Overseas
Additionally, accumulator pressure gradually drops by 4 psi every 15-20 seconds with engine off.
BigWrench55
Somewhere
With machine off pump the brakes until you have no pressure. Now start the engine and see what it will build up to. Like FWF said the brake charging pump will charge it to 2200 and kick off. With the engine still running pump the brakes and you should see the pressure go down and build up again around 1700 psi. If that is happening then your brake charging pump is working. Now shut the engine off when you hit full pressure on the brake accumulators. With the engine now off pump the brakes. I like to get 5 pumps before all the pressure is gone. I think the book calls for 3. Anything less than that you have a bad accumulator or accumulators.
RMadilla
Overseas
Paul,
Accumulators are brand new and pressure sensor is brand new just installed yesterday before I joined this forum. That's what we originally thought as well after diagnosing that it had to be bad accumulators, but still a no go. That's why we are so boggled by this warning message. Everything works like it should. Starting to wonder if its just the V-ECU acting up?
funwithfuel
Will county Illinois
Mechanic
Ok, the slow drop indicates you have some leakage at the one way check valve feeding the accumulators. 15psi/minute isn't terrible.
Let's check basic health of brake system.
1) monitoring brake pressure, pump brakes till pressure is around 1400.
2) start machine and observe pressure climb. At what pressure does it stop? Should be roughly 2200 psi. This is cut out psi.
3) pump brake pedal watching pressure, do it slowly and deliberately, your watching for the threshold of when the pressure stops dropping and begins to build back up. This is cut in psi. This should be close to 1800.
4) repeat the process 2 or 3X to get an average.
5) now we gonna check max brake charging, once the brake pressure has reached its cut out pressure, we need you to curl the bucket back over relief. You should see an increase of at least 200psi. You should now be at or near 2400 psi.
I suspect this is where your problem lies. Based on info you've already provided. If there isn't enough separation between max charging and cut out pressure, active brake charging runs over the pressure reducing valve for max charging. Since the sensor can't see the value it wants in 60 seconds, it continues to throw oil at accumulators instead of fan. What you'll need to do is adjust the reducing valve PB at the central valve. On that same block that you swapped MA5502, on the bottom edge, facing the trans is the pressure reducing valve for brake pressure. You want to loosen the jam nut and adjust it in until you reach 2400 to 2450 while holding bucket over relief. Good luck . BTW, make sure to place the frame lock before climbing into the turning joint. You could probably do this from underneath if she doesn't have belly guards.
RMadilla
Overseas
Item 40 is inlet check valve. This will more than likely account for your bleed off as minor as it is.
FWF,
Thanks for the input. I will let you know what my results are.
Also thanks for pointing out that check valve, it just looked like a regular hydraulic T-fitting whenever I was replacing the accumulators, didn't think anything of it.
funwithfuel
Mechanic
The T is a T , the fitting that screws directly into the manifold is the check valve. The fact that you have a T fitting says you have hydraulic parking brake. That T feeds the park brake release valve. There is a slight, very slight chance that it is leaking a little. Not likely though. Easy enough to remove from the equation, just take the T and branch line off for testing purposes.
RMadilla
Overseas
FWF,
My results are as follows,
2) pressure stops at 1807
3-4) each time I pressed the brake pressure would drop down to around 1620-1660 psi before building back up my average was 1636 psi
5) with the bucket curled back there was no psi change in accumulator pressure.
After completing this I went directly to the reducing valve to make adjustments. My guy sitting in the cab said that it jumped to 2150 psi and then would start dropping again as I kept adjusting. You could hear a change in the machine when it hit that sweet spot though at 2150.... Bad reducing valve maybe?
Also this loader does have the clamshell attachment. I was mixing it up with another vehicle we had in shop. Would this make a difference in anything? I know Paul mentioned it before when he was originally asking questions.
funwithfuel
Mechanic
Ok, let's back up to beginning. In the service screens there's a max fan speed test. This acts as bit of a hillbilly flowmeter. Full throttle, max test on you should see 1900 rpm or so. There are no adjustments that you can make to the fan circuit other than speed and direction (if it is equipped with reversing fan). This will tell us if your pump is healthy or tired.
You've said, best pressure attainable with pressure reducing valve is 2150. That's not getting it done. And that was done using your bucket relief circuit. That says you have a parasite taking your oil.
Remember that T fitting. You're going to remove it now. Cap the hose coming from the side so that you only have the hose from the central valve feeding the accumulators and the 2 hoses going to the brake valve. You have to cap that other hose, I suspect it will leak from tank quickly.
If my suspicions are right, your park brake valve is leaking to tank.
